Feb 14, 2023 #1 NiiBaa Mechanical Joined Feb 14, 2023 Messages 2 Location GR Dear all, i try to edit routing at solidworks and option is deactivated. Please advise
Feb 14, 2023 #2 ctopher Mechanical Joined Jan 9, 2003 Messages 17,527 Location USA, CA What have you tried? Click on part and edit? https://www.youtube.com/watch?v=uvYXsp7_PUw Chris, CSWP SolidWorks ctophers home Upvote 0 Downvote
Feb 14, 2023 #3 SBaugh Mechanical Joined Mar 6, 2001 Messages 6,691 Location US Is the Add-in Turned on? Scott Baugh, CSWP Mechanical Engineer Ciholas https://www.ciholas.com/ "If it's not broke, Don't fix it!" Click to expand... faq731-376 Upvote 0 Downvote
Feb 18, 2023 Thread starter #4 NiiBaa Mechanical Joined Feb 14, 2023 Messages 2 Location GR Add-in is turned on. It is created at assembly mode Upvote 0 Downvote
Feb 20, 2023 #5 SBaugh Mechanical Joined Mar 6, 2001 Messages 6,691 Location US Maybe it has something to do with the Design library of the items that are in the assembly. Do you have the central location to save and load your routing connections? This tutorial is very extensive maybe it has the solution in it: https://www.goengineer.com/blog/solidworks-routing-101-pipe-design Hope this helps, Scott Baugh, CSWP Mechanical Engineer Ciholas https://www.ciholas.com/ "If it's not broke, Don't fix it!" Click to expand... faq731-376 Upvote 0 Downvote
