May 26, 2021 #1 L Luke790 Guest Hi I am designing something up in Solidworks and struggling to get a corner done as shown by these lines. Not sure if you know which feature/advanced fillet to use to achieve this type of fillet/round corner? Thank you
May 29, 2021 Thread starter #2 C Cadasio Guest Would filleting the 3 edges, and then using the setback parameters help at all - maybe try changing the profile to curviture too? alternatively you could put normal fillets on, then chop the corner off to do some surfacing to give you exaclty what you want
