I am new to SW and have 2 questions to the forum.
1. I have a part which is at an angle in vertical and when I add a view in the drawing,the orientation is same as part.
How can I orient the part in vertical position, so that I can dimension it in vertical and horizontal axis?
2. When I make detail drawings for each part from an assembly, how can I add BOM for only these details in the sheet. For example I have detail drawings of 5 different items in one sheet and the BOM shows only 1 item in BOM table. Is it possible to add other 4 items to the same table?
Thanks in advance,
GL
Thanks in advance,
GL
