Solid Works 2003 problem install
blatte
CA
I've downloaded SolidWorks2003. I use Microsoft XP pro. While the installation, it happens a severe error VBAI60: 536878915. I downloaded many version of Solidworks 2001 and 2003 and the same errors happen everytime, what can I do to solve that ?
blatte,
Use the SolidWorks CD from your VAR. Bradley
The most common problem with the install is to forget to turn off your virus checker.
When I do any installs I sweep the drive and reboot, then use task manager to turn off everything not needed to actually do the install. The reboot to return to normal operation.
Another problem we have with XP has been cured by clearing the prefetch directory every reboot.
Crashj 'and bring in the dog and put out the cat' Johnson
SnowCrash,
What is the prefetch directory and how do you clear it? Since XP is derived more from NT than Win 95/98 is there something similar to this in the versions of NT and should we do something with it?
TIA,
- - -DennisD
In the directory vba, rename vba6.msi by vba6fr.msi !
