Hi everyone, congratulations on the high level of the discussions that have been going on here for the past few years. I've been reading and learning as much as I can, but there is one problem where I hope someone can provide some insights..
I am preparing a classic toyota for classic car races here in Europe. I have read a lot about basic setup procedures regarding initial spring, arb and damping rates. However most of these procedures seem focussed on A-arm or McPherson suspensions and no mention is made of the old solid axle type setups. Question that I am trying to tackle are:
Is it correct that a solid axle's motion ratios vary between one wheel bump (vertical rotation around other sides contact patch), two wheel bump (motion ratio == 1) and roll?
I'm having special difficulties visualising what happens during body roll. Do I consider the rear axle fixed and move the chassis around the spring base (attachment of springs to body), do I do the usual and take the lower spring attachment point and reference it to the wheels?
The ARB is giving me similar issues.. its bolted to the rear axle and the ends are attached to the car. The opposite of the usual setup. The mounts on the axle are spaced really close together compared to the arm-mounts.
Any hints on how to model a solid axle rear end are more then welcome.
Thanks!
Thanks!
