Solid not displaying right in drawing.
uGlay
I made a solid, put a bunch of holes on it, then put it on a drawing but the outline is not showing. only the holes.
Any idea what could be causing this? Nothing special about this part, just a bunch of extrudes and cuts.
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Are the outline elements highlighted when moused over in the drawing views?
Has the outline Line Format colour been changed, or somehow been hidden?
[cheers]
it was a multi-body part. i broke it up into an assembly and it all displayed correctly.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
I have seen a similar problem pop up now and then with cosmetic threads being toggled on or off for the given view.
SBaugh: Drivers are all legit.
Subwoofer: I havent noticed this with cosmetic threads but maybe because I dont require cosmetic threads in drawings.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Well be double sure and if they are legit I would contact your VAR about this one. Still seems like a Graphical issue.
Try this: faq559-1058
Scott Baugh, CSWP [pc2]
"If it's not broke, Don't fix it!"
faq731-376
uGlay,
This is a long shot...Activate the view with the problem...in the line format toolbar toggle the color display mode...see if this fixes the problem.
Jorge
Select the drawing view & change the draft quality to high quality (or vice versa) try this.
Mechanical Engineer
hisrik: do you mean the "cosmetic thread" options? I dont have any cosmetic threads on this part.
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
