Skulstad
Geotechnical
- Jul 23, 2002
- 4
In using a solid hatch for shading/coloring within a drawing and using the "Display Order" command to push it back behind lines running through, or around, the hatched area works great until... (surrounding lines are also brought forward).
XRefing a drawing with a solid hatch (previously described as in background through display order command) is brought to front or on top of other drawing entities. Only way found to 'get around' problem is to wblock out the hatch patterns and seperately reference that file, again performing a display order function, this time using references, not layers.
Any help would be great.
