Did you create in 2D or 3D model which you created a drawing from.
If in 2D did you use the model sheet or straight on the draft?
If yes to either, and assuming you drew at 1:1 why would you not want to scale? In fact if I understand what you are saying then fundamentally you want to scale it, say make it 2:1 instead of 1:1.
Select the view, up in the ribbon bar should be a scale setting. From the pull down select your preffered scale (you can create your own unique scale if need be).
KENAT, probably the least qualified checker you'll ever meet...
