I'm designing a low profile 3-position system using a DC solenoid(s) to create the motion/forces necessary. To maintain a minimum height - I was planning on using a non-magnetic conical spring (brass/bronze) residing within the bore that will return the plunger to its de-energized origin. Any background info on this concept (good/bad experience)?
Also - are there any inherent probelms / disadvantages with using a permanent magnet plunger (alnico, ceramic, ...) to be able to provide both a pull and return push force by reversing the current? Any experience with this would be helpful.
thanks
Ron
thanks
Ron
