Magnusheld
Industrial
I'm working on a project, were i am to design a opnening mechanism for some solar shading panels on the gable of a house.
the panels should be able to rotate from starting position (0 degrees) to almost 90 degrees.
I have been looking at gas springs in order to be able to lock the panels in variable positions between 0-90 degrees. It seems like a bit much though for 11 kg panels, so i was wondering if it was possible to use a some sort of combined mounting and rotate locking mechanism when mounting the panels to the wall? Kind of like a socket wrench mechanism. I have no idea what sort of mechanism could be called though og where to buy it??
Another problem is the oblique mounting surface in one of the ends. i don't really know how to solve that. This can be seen at attached image number 2.
The panels are 8 mm thick, 300 mm high and 2900 mm long. They weigh 11 kg.
