Russ0448
- May 9, 2003
- 7
I'm at a loss.
I have an object that is subject to solar radiation. I'm trying to understand what a good assumption for the heat flux would be. I have been told that a reasonable assumption would be 1000W/m^2. The surface of the object is painted white with (e=. 96 and Alpha=. 21). The surface temperature of the object is estimated at about 115F to 120F. The removal of heat is only going to be free convection and radiation back of the surface. The surrounding temperature is estimated at 95F.
I guess my question is : Is the 1000W/m^2 a reasonable estimation of the total (diffuse as well as direct) irradiation per unit area?
Also should I take into consideration the Atmospheric radiation associated with CO2 and H2O. I have reason to believe that I should, but am unsure of how to do so.
Any help would be much appreciated.
Russ
Russ
