How to figure out a representative soil strenght for foundations design looks like a simple task but sometimes it is'nt. Expecially when we start to talk about averaging.
This is what dgillette wrote (see thread "anyone near detroit?":
I would like dgillette to expand his views. Particularly, to me it would seem that in settlements problems, simple averaging (even geometric or harmonic) woudn't be a good idea, unless it's done over short lenghts, because the soil close to the foundation "sees" the load much more than the soil further down (to this regard soil is a little "near-sighted"). Hence the necessity to split the succession into thin layers (the Schmertmann's method).
As to failure problems, I agree that arithmetic average is sensitive to larger values, and that a failure surface, being lazy by nature (minimizing work, or maximizing entropy) would rather avoid stiffer layers. As GAfenton pointed out in an archive thread (256-96409), geometric or harmonic average would better reflect the laws of physics applied to failure surface propagation in soils. Nevertheless, if I have a vertical ECPT sounding below or close to a foundation, and if I assume there are no lateral soil variations, I would believe its data, properly treated, would be reasonably representative of real soil behaviour. Depth of representativeness should of course be chosen with discrimination. I favour 1 to 2+ times footing width, according to the presence of stiffer layers (which failure surfaces would like to steer clear of as much as possible). In average foundation project, measuring soil properties over the whole, potential failure surface, would be big probs (think about a slab foundation and how many field or lab tests we would need).
dgillette said:I would like to caution you about using statistical analysis of soil
properties to infer the mechanical properties of the soil mass on a gross
scale. This is a topic that has occupied much of my attention for the last
25 years.
For a compressibility problem such as settlement of a building, the
vertically averaged stiffness can be a pretty good representation.
However, for strength problems, it is the weakest link in the chain (the
weakest layer) that governs. What's needed is an average over a potential
failure plane for a slope or foundation. Vertical averaging can be
dangerously unconservative.
