Geotechnical76
I have been asked to look at the soil structure interaction of the following structure.
We have an existing 38-inch concrete water pipe lie which is encased in concrete at some point along the alignment with a butterfly valve in a chamber connected to the concrete encased section. The pressure in the valve is 100 psi when the valve is open while the pressure on the bulkhead when the valve closed is 75,000 lb. The concrete encased section is proposed to provide some resistance to the pressure. The top of the encased section will be 5 feet below the ground surface. The encasement will be 12 inches above the crown of the pipe and along both sides of the pipe. Since it is an existing pipe, encasement will be difficult to be below the pipe.
In addition, wing walls are proposed along the concrete encased section (on both sides, left and right). These wing walls will provide additional resistance to the 75kip load. What I looking for at this time are (1) the spacing between the wing walls and (2) the soil pressure (reaction) on the wing walls due to the valve load. The walls and the encasement will be constructed using an open cut and the trench will backfilled with granular fill. The existing soil profile indicates 3 feet of silt sand over a deep layer of medium stiff to stiff silty clay.
I am thinking that the pressure on the walls can be modeled assuming a passive earth pressure. The passive earth pressure parameters will be phi=30 degrees, gamma=120 pcf. My other concern is the interaction between the passive pressure zones between the wing walls since soil will be between them. I am using the 2:1 method of stress distribution behind the walls to determine the minimum spacing to avoid stress concentration. Any thoughts are highly appreciated.
