jdgengineer
- Dec 1, 2011
- 748
We are working on a residential project where the basement walls are proposed to be supported with soil nails. These will be designed by another engineer who is also doing the temporary shoring design so the soil nails will serve as both the temporary shoring and then have an embed plate cast into the permanent retaining wall to brace for the permanent condition.
There are some sections of the wall where the civil engineer is showing approximately 2-6' of fill above the existing grade.
I'm trying to understand how this would work with a soil nail wall.
I know roadway construction sometimes uses a MSE wall above a soil nail wall in similar conditions but I'm not sure how feasible that is here.
We will coordinate this with the other engineer who is designing the soil nails but just want to come with some ideas.
Could the top row of nails be designed for the extra retaining height and have the permanent wall cantilever above the top row? Could the fill be CDF or geofoam instead to reduce the active pressure and then just have the soil nails designed for the additional surcharge of the CDF?
Or are there other approaches to using soil nails in partial fill condition? The temporary shoring would not have any fill, just the permanent wall.
