dik...I read the other post as well. A few thoughts to consider....
Dessication will occur by one or both of two common methods...the first is lack of recharge because of the impervious nature of the construction above. The second is reduction of moisture by vegetation, particularly larger trees as they grow.
The impact of lack of recharge is related to the footprint size of the building. Obviously, the larger the building footprint, the more likely little or no recharge will occur near the center, thus more drying near the center. The lateral permeability of the soil will typically be less than the vertical permeability, so unless there is cross-flow drainage at the near surface level, dessication will occur.
Recharge piping under the building could be considered, assuming the construction occurred when the soil was in a swollen state. If not, recharge piping would likely cause swelling thus engaging the voidform to some degree. Recharge sources could be roof drains or surface drainage. A moisture content monitoring system can be employed to control the amount of recharge.
As for the vegetation, that can be controlled as long as you don't get into a fight with the landscape architect! A chainsaw usually cures that issue!
