GW is the designation in the Unified Soil Classification System for a well graded "gravel". The characteristics are that:
a. the overall material is more than 50% coarser than the #200 sieve size.
b. 50% of the coarse size (i.e., a. above) is gravel sized - retained on #4 sieve or 12.5mm).
c. The percent of fines passing the #200 sieve is less than 5%.
d. The coefficient of uniformity (D60/D10) is greater than 4.
e. The coefficient of curvature ( (D30*D30)/(D60*D10) ) lies between 1 and 3.
For completeness, the material would be called GP if points d. and e. are not met. If more than 12% passes the #200 sieve, the "gravelly" material would be classified as MH or MC depending on where the Atterberg limits fall on the Plasticity chart. If the material has between 5 and 12% fines, then there would be a dual symbol use (GW-GM, GP-GC, etc.)
This is given in almost all soil mechanics books as well as in ASTM.
