SOG Help needed. 1
jeremy123
Materials
Mar 30, 2004
1
OK, to start I would like to say that this site is a blessing! Now on to the task!
I am going to be constructing a bar/restaurant in the next few weeks, and would like a little help deciding the best design for the slab. The building will be either 30'x80' or 30'x100', not quite sure on that yet. The exterior walls will be framed upon the slab, so I am leaning towards footers, as well as #4 rebar grid 18" OC throughout slab. Is this overkill? The main goal is to keep cracking to a minimum, and keep vertical cracks from happening at all, as the concrete IS the finished floor.
OK, have at it guys. Tell me how YOU would do this. TIA for any/all advice!
It doesn't appear that you have done structural design before so I would suggest you get local help with that. As for the cracking issue, you should have control joints in the slab at no greater than 15 feet apart in both directions. For a 30x80 slab, I would put a joint in the middle of the 30' dimension, then space the other joints along the 80' dimension by 6 equally spaced joints. Similarly, if you go to a 100' dimension, divide the long dimension into 8 sections.
**Need Professional Development Hours / Continuing Education ??
**Try this course...
