As I am the one maintaining bpvinspector.com... I understand the forms cannot meet everyones needs and as long as the content is "essentially" unchanged from the Code, you are able to edit the forms as you see fit... I used to keep the forms updated in Excel but, it is a real task to keep them ALL up to date... All I do now is import the words directly from ASME's website and place fields selecting font size etc.... using Adobe X Professional.... which will allow conversion into Microsoft Word Forms.... where additional tweaking is needed. I would recommend investing in Adobe X Pro for many reasons along with the latest MS Word only because they are the most widely used general purpose software programs that Certificate Holders should have. Once you have a template of your own setup.... it is simple to replicate... and since the Code is always changing, it would be best not to rely on others to remain updated.... Itry to get all forms updated each year.. but can make no promises. Just my $0.02
FAQ731-376 A question properly stated is a question half solved.
