JAE
- Jun 27, 2000
- 15,590
I just spoke with one of our software vendors concerning their latest version that we just installed. It seems that their program now performs beam designs for the latest edition of the LRFD Steel Specifications (3rd Edition) only. What prompted my call was my own view that what they were doing was simply wrong and here is why:
1. They allow the user to specify various building codes from various years (i.e. UBC 1994 or SBC 1999).
2. To perform LRFD design, they lock you into the 3rd Edition.
With both of the above being true, There may be times that I simply cannot "meet code" with my design as a municipality or other governing body will adopt a CODE, such as the UBC, which in turn, references a specific material SPECIFICATION. For example, the 1994 UBC refers to the ACI code that existed before the year 1994. Thus, for me to design under the 1994 UBC and then use the new 2002 ACI 318 code wouldn't work....they really don't mesh.
If the new LRFD spec has a design portion that results in SMALLER sized beams than that required by the 2nd Edition, or the 1st, then technically I'm not meeting code and it would be very difficult to even know when I'm not (nothing to compare to).
Just because the new edition is based on latest technology doesn't legally allow me to use it. When I prepare my drawings, I must indicate on the plans that I meet a certain building code so the governing municipality will provide a building permit. I can't do this under this software vendors "method". I want them to keep the earlier versions of the LRFD for me to choose from during design and they don't believe that this is necessary...
Do you agree? Or am I making too much out of this technicality?
