I have a dilemma. Basically, Im implementing a soft starter to replace a old reduced voltage starter circuit. I found several potential good soft starters. However the problem was I overlooked the fact that the power system that the soft starters will be connected to is corner grounded delta system. This is an old power system arrangement, that is rare today,and mainly in the US. Many soft starters are not compatible with this type of system. I came across some soft starter that "claimed" they were compatible with delta grounded. However, whenever I asked the vendor's tech support person, why they are compatible.Most did not know why, and some didn't even know that their soft starter was listed as compatible. The tech support individuals could never fully explain what makes a soft starter compatible compared to one that is not. I would like to know, from anyone with experience, what make these soft starters compatible to a delta grounded power system? What specific properties on the soft starter makes it compatible? Is there a unique way that I must connect the soft starter? Thanks for any help
