LWalke
Chemical
- Nov 22, 2006
- 2
I have a process that is somewhat sensitive to sodium. The level in the feedwater must be reduced from 100ppm to 30ppm. The required feedrate is not that high - only around 1000 gallons per day. Hence, batch or continuous treatment is suitable...obviously, coninuous would be nice but cost is a major consideration.
Does anyone know of a relatively cheap way to do this? An ion exchange approach is probably preferred. Again, dumping a chemical into the water and stirring it out in a tank for a couple of hours and pumping through a polishing filter would be a perfectly suitable approach. The question is what chemical is best for this and easily obtained at a reasonable cost?
The sodium in the water is in the form of sodium chloride and sodium sulphate.
Reverse osmosis has been recommended and that is an option. However, I find it hard to believe that other, less costly solutions are not available.
Thank you very much for any suggestions.
