I'm trying to create a model to be able to calculate the runoff induce by precipitation (of both rain and snow). To be able to access both the volume of runoff and the peak discharges...
So i've created a HEC HMS model with subbasins, reaches, etc. I decided to use the Deficit and Constant method for calculating losses (i usually use SCS and CN number) and the SCS lag time for Transform.
I have in hands, both precipitation and temperature on an hourly basis which i've entered in the model so i can use the Temperature-Index method.
The model is calibrated for "storm-events" based on measured flow rate. And the model is giving good results (i'm almost surprised myself...)
So now ... I'm trying to simulate the snowmelt for a long term event (say on a yearly basis). The model runs and everything seems fine for the months where there's no snow (when compared to measured data).
BUT... When it comes to snowmelt... nothing. It's like if the program takes snowmelt in account but when it creates a precipitation from it to put it back in the model (thats how i see the process) the runoff induced is "taken" by the losses (mainly because the Initial abstractions > runoff).
What to do ? Lower the initial abstraction? Even if it's giving good results vs measured flow rates. Model separately months with and without snow?
Any ideas would be fine right now !
