Snap setting
  • Thread starter Thread starter Baldasarre
  • Start date Start date
B
Baldasarre
Guest
I am using AutoCAD 2007. When I am trying to draw an 3D polyline and when I try to snap point to point it does not snap to z elevation and it keeps the first points z value, should some setting to be changed to get it to snap to the 3D points?
With regards.
Mine works fine
MD 2007. Are using regular polyline command(_pline)? You must use the draw 3D polyline command (_3dpoly).
Hi Baldasarre,
See whether OSNAPZ is set to 0 (Zero).
Regards.
