O
old_dog
Guest
I can't seem to get the snap feature and even the inferencing to work. In sketch, for example, adding a feature to a model with existing features, and in drawing a line, it seems to hilight the end of an existing line, but then it puts the new point/line almost there. I can go into relations and fix the point, but it is really tedious. Drawing a rectangle is a waste- it will not "attach" to existing lines when sketched, and when you put one edge collinear, it breaks away from the rectangle leaving three lines floating. So to draw a simple rectangle, you are better off drawing four separate lines (which is not right).
I'm a very occasional user trying to warm back up, and this is driving me crazy. In sketch settings Iactivated the "automatic" relations (can't remember exactly what it was called), and I got the ortho to work finally, but all the normal inferencing stuff is dead. In 2007 sp0, xp,if that helps. I feel like I havesome obscure setting wrong, but can't find out what it is.
Thanks for anty help!
