smoothing imported model
  • Thread starter Thread starter brmdjoko
  • Start date Start date
B
brmdjoko
Guest
i have some models of car, turbine blade etc. in AutoCAD format (surface model) and succeeded importing into WF.
but the imported model so 'jaggy'.
does any one knows how to smoothing it? (using ISDX maybe)?
thanks
Some of the import options set in config.pro may help you. Most of them start with intf3d_... I just looked at some of the options and it looks like you might have to check export options of AutoCad. Pro/E has more export options for controlling curvature and surface smoothing, but little I have seen for import options.
Thanks donha.
I'll try it in a couple days. I will inform you all whether succeed or not.
