Let me explain little bit of my situation.
I’ve started to work with designs which have been cloning for years (15years?). Editing, adding or deleting components, Reference Sets; Updating the new and obsolete wave linked pockets through the assembly; what a lengthy process to get the work done. After a design review, have to go through again the same process. For me, this is a waste of resources. If they were made smart in the first place, could have got the work done with few clicks.
In this situation, I started new methods I used in the past. For instance, now when I edit/add/delete a sketch point, then quantity of components and all their pockets and depths in the assembly including threaded holes and information update automatically and smartly. (I found this is a new method to most of the NX users which they haven’t seen before). Stock sizes and drawing detail notes update automatically. (Since these are old designs, I didn't try PDW methods) Basically I’m making the old designs smarter and reducing repetitive manual work and errors/typos.
Now I’m trying to make the drawings smarter.
Ex. In the original design, the rectangular plates’ sketches were not square to their absolute datum. But the drawing views were rotated and aligned with XY and had created the orthogonal views. (= drawing is correct in that base view orientation)
When I open the new cloned and then modified (rotated as required for the new project) model’s drawings; the Base View is at a rotated angle and with the orthogonal projected views corresponding to its side views. Please see the attached sample drawing. My requirement is to rotate the new Base View so that the projected views update smartly. I.e. bringing the new crooked orthogonal views to default views as before.(= dimensions coming back to their original status.)
Some may say that redoing the view is easy, but it is an addition to the work load especially with dimensions with special tolerances, notes and texts attached to them. If I'm not mistaken, in NX must dimension first then have to go back to edit mode to add its tolerances and related notes. Do you guys enjoy this much of work?
Michael Fernando (CSWE)
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
