steve41337
My Engineering license and experience is in Mechanical Engineering and HVAC. I'm also a licensed General Contractor working on an unusual project pouring in place two office desks shown in the attachement provided below. The countertop at the top of the page is my bigger concern of the two. Looking at that slab you will notice it is supported on the left side by a built-in cabinet (no problem for that cabinet to support the weight of the concrete). Along the back wall and right right side wall there will be short pony walls that will also adequately support the weight of the concrete pour along these adjacent wall perimeters. By design there are no other supports for the L shaped countertop. The back wall and right side wall are masonry bock so it is possible to anchor rebar into these walls. My instinct is to tie into the back and right wall with #3 rebar on 4" centers. I know the pour will not fall down but I'm not sure it will not crack because of the large unsupported area of concrete countertop where there is no direct support.
I have two questions: 1) is there any advantage to anchoring the 4" x 4" rebar lattice to the adjacent masonry walls behind and to the right of the concrete pour? And 2) Assuming no more than 2 men each weighing 200 pound sit in the edge of the approximate center of this slab how likely is it to crack somewhere; and what psi concrete would be required to make this monolithic pour concrete slab rigid enough transfer its loaded weight to the three perimeter sides without cracking anywhere? Obviously smacking it with a sledge hammer in the right place would easily crack it but I'm not concerned to make is resilient to that kind of abuse.
The bottom of the pour frame will be lined with 1/2" cement board or plywood (supported underneath during pour and curing) with a finished 3.5" front edge (3" concrete depth poured above 1/2" cement board with cement board abandoned in place after the pour. In other words the abandoned cement board will not be visible from the front edge of the concrete pour where a full 3.5" of concrete will be visible (everywhere else the concrete pour is 3" deep on top of 1/2" cement board abandoned in place). My gut instinct is that a 4" x 4" #3 rebar lattice poured with 5000 psi concrete mix 3" deep (plus some glass fiber to further increase concrete strength) should be strong enough to resist any cracking. But I can't say that for sure.
