small size ADC card
masudasim
PK
Hi
I need a small size (approx 50 mm by 100 mm) low noise 16-channel ADC card sending data on gigabit ethernet for real time data acquistion.
Minimum sampling (simultaneous) requirement per channel is approx 48 Ksamp/s/ch.
I know i ask for lot of things in very small size but if any one know some commercially available adc cards near these specification, let me know it please.
THANKS
You'll probably have more luck finding a tiny Single Board Computer that has those interfaces. Ethernet is almost a given. 16 channels of ADC is a lot. "Low noise" is relative.
Thanks for reply. Do you have any SBC in mind which may be useful for me?
As an example, here's one I just found using Google. SBC65EC, ~58mm square. 12 analog inputs, not 16.
There are quite a few data acquisition modules using the search terms: Ethernet 16 analog inputs. But most appear to be bigger than your size constraint.
If you can wait, others may reply after the holiday weekend.
