twl724
- Nov 11, 2011
- 3
Without any preface here is the problem...
I have a 1" dia. stainless steel (for lack of better words) tank. There is a 0.25" dia. hole located on its side. The tank has an approximate wall thickness of 3/32". A fitting is needed to connect the 0.25" dia. hole to any standard NPT thread size, preferably 0.25". The quarter inch hole cannot be threaded because the wall thickness of the cylinder/tank (~3/32") is too small, even for fine thread. I have looked into various 0.25" bulkheads. However, all bulkheads of an appropriate size have criteria that prevent them from working. The first criterion for small bulkheads is that the tank size must be sufficiently large as to allow the bulkhead to seat properly against the tank's curvature. The second criterion for bulk heads pertains to the hole size. A quarter inch bulkhead generally requires a hole size of 7/8". The hole is located such that it can not be modified. One other possibility that I have contemplated is welding... this is a last resort.
In the exploded view provided, the leftmost piece is in question.
Please ignore the other excess.
What do you guys think? Any input would be much appreciated.
T.W. Lewis - Mechanical Engineer
Virginia Commonwealth University
