Wbruseski
- Jul 18, 2001
- 18
I am designing a gazebo structure for the wind loads of Florida. The gazebo will generally be 8-sided with screen as an option. I don't have a problem getting the wind loads, but have some questions on the design.
What are the accepted assumptions for a free standing strucure? For an open structure, is the windward pressure applied to the area of the posts and the gabled roof?
I obviously need fixed bases to handle moment. Is the only way to imbed the posts in concrete? Is core-drilling existing slabs then refilling acceptable? Any type of screwed or anchored connection considered fixed for concrete or wood deck?
Also, I came across a set of plans that has this statement:
"ROOF SYSTEM
RIDGED TRIANGULAR MODULES CONNECT TO FORM A CONIC ROOF SYSTEM. THE COMPRESSION RING IS INTEGRAL TO THE CONIC DESIGN AND ALLOWS RESULTANT FORCES TO BE PERPENDICULAR TO GRADE."
What is a "compression ring" and how does it allow the resultant forces to be perpendicular to grade?
Any insight to this design would be appreciated. Thanks.
"ROOF SYSTEM
