beej67: Curious how you organize your CAD files on your server. Do you have references for blocks, titleblocks and architectural backgrounds all in the same folder as your current CAD files? Do you copy the whole thing to an "Issue" folder every time you issue a revision to the drawings?
We don't have large numbers of sheets in our drawings, and try to put all the sheets in one dwg with minimal XRefs.
I copy everything I need to reference into the same project folder. Blocks, tifs, images, title blocks, USGS quad rasters, whatever. I do not save CAD files from previous issues, because those always get mucked up anyway by changes to the references. Instead, I keep PDFs of each issue, which are dated and then secured against modification with a password. In fact, I don't print from AutoCAD at all, I send the PDFs themselves to the print shop. Mostly I find that clients just want the PDFs, so I only ever print if I'm submitting for permit or issuing CDs.
Most of the old methods regarding referencing blocks and the like in a central location were holdovers from back when storage space mattered. It no longer matters, period. Most of the old methods regarding keeping revision history in DWG format were likewise holdovers from back when PDFs weren't a thing, and everyone had to plot out of AutoCAD. I just dumped the holdover policies and moved on with my life. Revision history in DWG was a nightmare, especially if you have your blocks in a central location, because suddenly new changes to your blocks show up in old already-issued drawings. And if you are pulling an old revision for some reason, chances are that reason is some kind of disagreement about what you sent out, so you definitely need to know exactly what you sent out.
I come from a background where we would have three or four XREFs blended so we could have multiple designers working on the same project at the same time. One doing utilities, one doing profiles, one doing grading, etc, in separate DWGs that reference each other. As I'm a smaller shop now, I much prefer to have everything in one file. I'm iffy on survey - sometimes I keep it in an XREF, and sometimes I just drop it in as a block. It's nice to be able to move survey text around, but you run the risk of accidentally deleting something important, so I usually lock the layers.
my .02
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East -
