For Slurry Walls and Deep Soil Mixing, is there a technical guideline or rules of thumb for selecting a) offsets from existing structures and b) panel sizes (width, not thickness). I have three cases, and I assume that the criteria will be different for each.
1) Continous footings
2) Isolated footings
3) Friction pile foundations
What I am after is preventing collapse of the excavation for the panel when it is surcharged by building loads. For continous footings I would assume there is greater redundancy because the load can redistribute (either side of panel excavation). For friction piles, I'm worried that if you get too close you loose friction capacity.
In my mind, the criteria would be based on the lateral load that a bentonite or polymer fluid (and concrete later) can exert laterally on the side of the excavation.
i.e. Soil pressure + Surcharge pressure <= Polymer/Bentonite Fluid pressure
......in order to prevent collapse of excavation and/or loss of bearing/friction of foundations adjacent.
Any insight would help. I've read papers and talked to contractors installing these system 1-3 feet away from foundations, and I'm looking for logical reasoning.
