Slurry Modulus for Pipe Bedding
moe333
Geotechnical
Hi all,
I am considering recommending 2,000 psi slurry (lean concrete) to bed a 96" steel pipe. Bedding 10" below pipe and up to springline. I typically recommend E' of 1,500 psi for crushed rock, and think I could go higher with sluury but not too sure about it. Anyone have any experience on what a reasonable E' would be for slurry?
Correction to my original post; 2,000 psi concrete would not be considered slurry. Any thoughts on what E' to use for a true sand-cement, say 2 sack slurry with 500 psi strength.
CLSM would have a modulus of around 500ksi. Soil-cement,compacted would have a modulus of around 250 to 300 ksi. A slurry with an unconfined compressive strength of around 500 psi should have a modulus in the 300 to 400 ksi range.
The Bureau of Rec. has tables showing E' up to about 3,000 psi for well compacted SW. But I think it should be a function of the pipe depth, trench width, adjacent soil, depth of backfill as well. Anyone have a good reference that accounts for some of these factors?
moe333...are you sure on that one? Seems awfully low. We can get 10ksi out of unstable sand. Graded aggregate base would be in the 40 to 60 ksi range.
Ron, yes..USBR E' values for buried pipelines are 3,000 psi for slightly or well compacted crushed rock or well compacted SW/SP. Someone told me AASHTO may have tables that take into account the factors I discussed above. I was trying to see if anyone has values for something like a 2 sack sand cement slurry.
A "2 sack" sand-cement slurry is much like CLSM. The modulus would be in the 300 to 500 ksi range.
