ASME Y14.5-2009
If a slot (groove) width is dimensioned with a direct toleranced dimension (10 mm ± 1) and one side of such said slot is profiled (located) from a datum reference frame (profile xxx |A|B|C|), does the xxx value for the profile should be smaller than 2mm (total size for the width of the slot)?
Note: I know I can use position to locate the middle plane of the slot (and not locate its one side with profile from the DRF), but into the slot is inserted a snap-ring which is biased against one of its side therefore functionally driven.
Functionally the snap-ring biased groove could be within 5mm from the DRF (location of one side of the groove-width of the slot) and the groove/ slot could only be within 2mm total tolerance.
Any issue with this approach? Is it valid within Y14.5?
I am asking in the light of paragraph 8.2:
“Where used as a refinement of a size tolerance created by toleranced dimensions, the profile tolerance must becontained within the size limits.”
