I am looking at a situation where I have a performance "platform" (NOT a stage) with sound deflectors that will be moveable in the vertical plane. The deflectors constructed so as to be at 2 angles, 12 degrees and 32 degrees, with no means of retaining heat from a fire.
shows a section through the deflectors.
In plan view the deflectors are approx 7'6"x7'6".
Is it worth trying to get sprinklers into the deflectors per NFPA 13 8.6.5.3? 8.6.5.3.3 would seem to allow me not to have them in the deflectors since the deflectors are not "fixed".
I am open to suggestions for protecting under the defelctors.
Thanks in advance.
Bill McDonald, PE
Thanks in advance.
Bill McDonald, PE
