rockman7892
- Apr 7, 2008
- 1,176
I had posted a previous thread where as a result of some of the responses I had questions regarding why VFD open loop control had a larger slip and speed error when operating at low speeds. I thought I would start a seperate thread to discuss this issue.
I understand how the magnetizing current (flux current) and rotor current and field interact in the induction motor to produce a slip and therefore the motor torque. I also understand the motor equivelent circuit. I have been trying to think however what casues the slip error calcuated by the VFD to increase with decreasing speed. I cannot seem to come up with a reasonable explanation? Can someone help explain why slip error increases with decreasing speed, and why below 4Hz or so the drive can not acurately control the speed or torque of the motor in open loop control?
At first I thought it was because the angle between the magnetizing current and the rotor current would be small, and the drive couldn't acurately distinguish between the two, but then realize that this angle is only small for low load values. Even at low speeds we can have high torque requirement and therfore have these two vectors at a pretty large angle.
