phamENG
- Feb 6, 2015
- 7,662
In all my past historic projects, the mechanical was put up on the roof and/or in a closet. Have one now that has units on the ground outside and they're running lines through the walls.
Historic brick masonry (100+ years old, 2 to 4 wythes thick, solid with no cavity).
Having trouble deciding if I want to have them drill through the wall or remove bricks individually, cut them, and replace them. Then, once the sleeve is in place, to I have them dry-pack it or inject epoxy into it? They can fill the sleeve with a typical penetration sealant, but I can't make up my mind on the sleeve-to-brick interface. Anyone have any ideas/words of wisdom to share?
Thanks.
Thanks.
