I am designing a slab on ground for a single story dimensional lumber framed residential addition. A 10x40 slab will be attached to the existing slab system with rebar dowels. The below grade geometry of the existing slab is unknown as is the reinforcing. There is no soils report for the site. I was planning on basing the design using guidelines from 1997 UBC Chapter 18,Div III section 1815 assuming moderately expansive soils. Is there any other guidance that I can reference. My only other references pertain to much heavier buildings (ACI, mat foundation design etc).
