Slab-on-grade maximum pour size
ajk1
1,791
Two questions:
1) Is the ACI recommendation for slab-on-grade pour size 9000 SF? If so, in which ACI document is this?
2) Is there a maximum recommended length of pour?
For saw-cut joints where "sizable" shear transfer is required across the joint we use steel plate dowels like DANLEY Plate Dowel Cradles:
We always use WWF (aka mesh or fabric) with min of 8mm dia deformed wires at 200mm c/c, chaired up on correctly sized plastic supports chairs so it stays in the top of slab - way different to the US practice of "chicken mesh" in SOG.
The only SOG's that I have seen without reinforcement (other than engineered unreinforced pavements of significant thickness) are council/city footpaths, and driveway crossings to dwellings.
Details are not clear from that link, but is that OZ/NZ connection like a 4 inch (100 mm) hollow tube slipped on to the stub ends of a cut mesh wire. (It is slipped over the mesh stubs before the pour, so it is concentric to each mesh wire; but the hollow tube is not crimped to both mesh stubs.)
DANLEY's are a fully prefabricated dowel plate assembly in 3 m lengths, with SOLID 6mm or 10mm thick plates, slipped into alternating HDPE slip-sheaths. Prefabed to correct depth to match the design slab thickness. First install the assembly over the proposed joint location and then install mesh/fabric either side of assembly joint. Place conc, then saw cut to required depth.
If I may return to my original question, about whether any limit should be specified on the length of pour of slab-on-grade, to avoid slab performance issues, or excessive opening of the joint between pours when the slab dries out: Is it the consensus that there should or should not be such limit? If there should be such a limit, what do you think that it should be, for the normal slab placed on 6" to 8" clear crushed stone granular fill on soil subgrade, assuming the concrete is not a special low shrinkage mix?
60 feet?
75 feet?
100 feet?
150 feet?
200 feet?
no limit?
If it is a poll then my vote is no limit provided there are no constraints or man hours or supplies.
There are literally thousands of miles of interstate highways and freeways as well airport runways and taxiways, all constructed of jointed plain (un-reinforced) concrete. Some state DOT's do require full slab reinforcement, but plain un-reinforced concrete is by far the most commonly used.
