StructureMan44
What is a good resource for design a slab on grade subjected to a column load? I have a column with an 18kip vertical load and soil with 150 pci subgrade modulus and I'm wondering if I can use a 12" slab. Hopefully there are tables that will eliminate the need for FEA.
Of the two resources I have ACI-360 appears best suited for a grid of posts and TM 5-809-1 appears best suited for walls at the center and edge of slab.
