Lion06
- Nov 17, 2006
- 4,238
I have an existing reinforced slab-on-grade that we are going to post off of. The slab is 6" thick and reinforced with rebar, not mesh.
The post loads aren't huge (they vary from 2kips - 4kips), but I am concerned about cracking in the slab. I've looked through ACI 360 (It's an old one, it was copyrighted in 1992), and I want make sure I'm looking at this correctly.
There are two tables (one for wheel loading and one for post loading) that, when you learn how to read them, give you a required slab thickness. This is based on unreinforced concrete, using the modulus of rupture of the concrete with a Safety Factor. The table for the post loads is somewhat limited in that it doesn't list contact areas greater than 80 sq. in. and it doesn't give modifications for a subgrade modulus other 50 pci.
Using these tables (with the unreinforced assumption) makes sense since we're trying to prevent cracking, and the steel contributes little to the actual cracking capacity. I believe that the acual load carrying capacity is increased by the rebar, but that the cracking load would be the same (or very close to the same).
My first question is am I going down the right road here or am I barking up the wrong tree?
My second question is if there is any more recent (and modern) design/analysis procedure by which to determine the adequacy of a slab-on-grade to take point loads without cracking?
