  • Congratulations IRstuff on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Slab and Beam design
stanleyshum1997
9
Currently I use Manus to compare my calculations with Manus’s app from iPhone 14 Pro. But i don’t know whether the calculations by Manus are correct. Can you please check the calculations attached by Manus app, assuming all the dimensions of the beam and slabs are correct, and all the parameters in the calculations are correct?
  • updated_design_validation(1).pdf
One of the easiest ways to verify an application is to compare results of a run to an example calcs you have previously done. You can also pick a textbook and run two and examples to see how it differs.
