1. Is there a keyboard shortcut for locking the mouse to one of the principle axes (x, y, or z) when drawing a line? I know I can type in an angle or use the alignment indicator for this, but both of these can be a little tedious if doing this a lot. Some applications let you hold down the x, y, or z keys on the keyboard, but that doesn't appear to work here.
2. When sketching in the ST environment, how do you specify a parallel plane to sketch on (rather than a principle plane or one defined by a part face)?
Thanks. -Pat
Thanks. -Pat
