R
RexAtHighSpeed
Guest
I need to lean on the experience of the experts in this
forum to suggest an efficient method of creating a
series of sketches to be lofted to make a port (intake
or exhaust).
I have modeled ports for years using Pro/E but now I
must use SolidWorks. In Pro/E I used four conic arcs to
create the sketched sections and it was very easy to
control the size and shape of the sections. I haven't
been able to find a way to do the same thing in
SolidWorks, although I'm sure there is a way. The loft
will go from round (at the valve) to rectangular with
corner radii. I want to be able to control the distance
of each wall from the port centerline. I also need to
control the angle of the walls and the size of the
corner radii.
Any suggestions?
or exhaust).
corner radii.
Any suggestions?
