sketch in the bakground
  • Thread starter Thread starter kenshinV10
  • Start date Start date
K
kenshinV10
Guest
Helo I am wondering if it is possible to put an image in the bakground witch I then can make a sketch on. Instead of having it on a pice of papper at my desk to look at. I am using SolodWorks 2007...
Here's 3 options:
1) Convert your raster format picture into vector format DXF and import as a sketch
Several software packages will do this, including some freeware if you search around a
bit.
2) Insert your picture as the ViewPort Background for SolidWorks:
Tools>Options>Colors><select> Image File and specify directory path to picture file
3) With a SolidWorks part or assembly file open, Insert>Customize Menue><check box for "Picture" if not already selected>
Then Insert>Picture><specify directory path to picture file>
You'll need to scale the sketch after tracing the picture. With the sketch active, select all, RMB (Right Mouse Button)>Scale Entities> enter scale and reference point in sidebar.
tnx now I can start working...
Better way?
I just received a tech tip from solidworks-community.com and there's a better way- insert the picture in a sketch!
To insert a sketch picture, have a sketch active, and select Tools\Sketch Tools\Sketch Picture. After this is selected, the Open dialog appears.
Check SolidWorks website (link below)
SolidWorks Tech Tip
Insert A Sketch Picture Is The Way To Go.
I've Use Corel Draw "trace" To Convert Raster To Vector But The Files End Up Huge.
Good Luck.
