Sketch entities flipped
cubalibre000
IT
I've opened a part that before in NX 7 was correct and now has errors.
I've seen that some lines in sketch are flipped. See attached image.
For lines with dimensions I use the alternate solution, but for radius ?
I tried to delete the radius and create again, but all the feature after the sketch need to be reassociated and sometimes is not so simple.
Thank you...
Using NX 8 and TC9.1
Hi Cubalibre...
This has been an issue for quite some time now...Best practice is not to add your blends and chamfers in the sketch...
Such features you need to apply on your solid.
Ronald van den Broek
Mechanical Engineer
Cad Environment Coordinator
Wärtsilä, Propulsion Services
NX8.5.2 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
I will do this, using external radius+thinkness expression to substituie the radius in the sketch.
Thank you...
