sketch constraints
  • Thread starter Thread starter aval_29
  • Start date Start date
A
aval_29
Guest
how can i make sure that may sketches are constraints? thanks
If the colour of the sketch...
We found this comment of the Autodesk discussion boards. It may help answer your question.
Reply From: RobV
Date: Mar/31/06 - 14:25 (CST) NEW!
If the colour of the sketch is dark (depending on your theme), it is fully
constrained.
Thanks.
3DCADTips Support Desk :cool:
Use the Auto Dimension tool.
Reply From: Brian R. Iwaskewycz
Date: Mar/31/06 - 14:28 (CST) NEW!
Use the Auto Dimension tool. If it reports that zero constraints/dimensions are required, then your sketch is fully constrained.
Brian R. Iwaskewycz
CAD Systems Manager
Core Furnace Systems
Thanks.
Reply From: Kent Keller
Date: Mar/31/06 - 14:32 (CST) NEW!
That is what I do when I am not sure. You can't always trust the color.
Kent Keller
Thanks.
Reply From: RobV
Date: Mar/31/06 - 14:39 (CST) NEW!
Good point Kent - There are times when the colour will show fully constrained but when you exit the sketch and go back in there may be a green line. I should have thought of that.
Rob
Thanks.
Reply From: Sean Dotson
Date: Mar/31/06 - 14:57 (CST) NEW!
There are other times that the color does not change until you try to "pull" on the line or point. Then it changes color. Such simple things....
Sean Dotson, PE
RND Automation & Engineering
www.RNDautomation.com
www.mcadforums.com
Thanks.
Reply From: JDMATHER
Date: Mar/31/06 - 15:09 (CST) NEW!
And if you're not sure what constraints are needed if it still needs constraints drag corner points - it should then become obvious i.e coincident, perp, tan ...
Thanks.
where do i find the Auto Dimension tool ??? how does it look like.
thx
Brian R. Iwaskewycz
CAD Systems Manager
Thanks.
