GaryFisken
This post will be part rant and part a desperate call for help.
Background (you can skip this part)
I work for, what I would guess, is one of the bigger companies using NX. We have recently switched from NX6 to NX8.5. We have our own CAD methodology that must be followed for the models to be as robust as possible. Since the switch, at least once a day I am finding something new that frustrates me, whether its a bug or a new feature. NX8.5 seem to have a lot of bugs and is plagued by many, MANY poor design choices by the development.
The Problem
The biggest source of frustration is the new "improved" way of constraining sketches. And yes, I know that you can just click the lines and a menu will pop up offering you available constraints.
We build most of our models using lots of datum planes and then constrain lines to these planes. Of course, you cannot select the datum planes inside sketcher since the default selection filter is Within Active Sketch Only (I don't see an option in Customer Defaults to change this).
So I switch to Within Work Part Only, but then I get a seizure from all the flashing on the screen. It wants to select, not only the datums but faces and the bodies in the work part (not that you can constrain anything to faces or bodies in sketcher). Naturally I check Detailed Filtering and de-select faces and bodies from the Types tab (in NX6 they aren't even present in this list). I use this until I realize that I no longer can select End point, Midpoint etc. from the curves inside my sketch.
Can anyone suggest a better work flow or some settings that can make my life easier?
Since I am likely stuck with this version of NX for several years to come I ask you for help with this particular problem.
The Problem
