Sketch-based features & Pad missing...?
  • Thread starter Thread starter justanotherdj
  • Start date Start date
J
justanotherdj
Guest
I'm new to Catia and trying to give me self an understanding of how to use it before I start a course in January.
I've been following guides on line, designing basic parts.
I'm following instructions to sketch a ring gear which I have used before.
I have sketched 2 circles, added constraints, exited sketcher and then when to hit the pad button but it was missing. So i through i'd do it the long way, as I have done in the past. I checked in inserts for sketch-based features but that also seems to be missing. In fact my whole insert selection is different to what I am seeing online. From images I have seen insert should look something like;
Insert -
Object (blanket out)
Body
Constraints
Sketcher
Axis System
SKETCH-BASED FEATURES ***
Dress-Up Features
Surfaced-Based Features
etc...etc...
OR (and I think this is how mine was originally)
Insert -
Body
Body In a Set
Geometrical Set
Ordered Geometrical Set
Insert new body (blanket out)
Annotations
Constraints
Sketcher
Axis System
but mine reads
Insert-
Object (blanked out)
Body
Body inset
Ordered Geomtrical set
Sketcher
Axis System
wireframe
Law
Surfaces
Volumes
Operations
Advanced Operations
Constraints
Annotations
Views/Annotations Planes
Analysis
Advanced Replication Tools
Knowledge Templates
Instantiate From Document
Instantiate From Selection
Advanced Surfaces
Developed Shapes
BiW Templates
Any help would be greatly appreciated because i'm otherwise stuck and do not wish to look like a dummy when I start the course!!!!
I think you're in the wrong workbench, since you have the Surface tools in your Insert menu. Use the START menu in the top toolbar and pick the PART DESIGN workbench.
Thanks, worked a treat.
Schoolboy error on my behalf, like I said i'm still getting to grips with it :)
Thanks again.
