Continue the horiz. bracing out and into the wall that runs parallel to the OWSJ’s. You can’t just stop any bracing in thin air and expect it to be very effective. And, you don’t accomplish any effective bracing when you brace to another equally unstable member, they just move together in an unstable way. Put an x-brace in btwn. two interior OWSJ members to stabilize the system. Be careful putting an x-brace or diagonal btwn. the last OWSJ and a wall, because the wall doesn’t deflect vertically, but the jst. does. And, the x-brace or diag. will induce some nasty secondary loads.
